查看: 2|回复: 0
12 dollar winch anchor for 200
发表于 2021-9-1 00:26:41 | 显示全部楼层 |阅读模式
well i started off needing to make a longer earth anchor for the duck boat since i couldn't find one in town and didn't want to order one here's how it broke down new radnor oxy and acetylene valves 120 bucks fill oxy 16 bucks fill acetylene 45 new 25 foot oxy ac hose 20 first i got the same size rod then heat up rod and bend into a eyethen cut both pieces to length and split down the middle on the band saw very time consuming clamp together there is a 5 inch overlap and finally bevel and weld my welds were with 35 flux core and not the best since i have now determined i need a new liner anyway just have to finish and paint and hopefully i wont have to use it and this completes building a 12 dollar anchor for 200350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:I just love projects that follow that same type of path.
Reply:Originally Posted by umahunterhere's how it broke down new radnor oxy and acetylene valves 120 bucks fill oxy 16 bucks fill acetylene 45 new 25 foot oxy ac hose 20
Reply:That always happens, you need tools and materials to make something. I don't understand why you cut it and then welded the same area? Was it attached to a longer piece of round stock?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Aint it the truth!A good guess is better than a bad measurement
Reply:Originally Posted by MicroZoneI don't understand why you cut it and then welded the same area? Was it attached to a longer piece of round stock?
Reply:just have to finish and paint and hopefully i wont have to use it and this completes building a 12 dollar anchor for 200
Reply:Originally Posted by umahunterit was to short it started as a 2 foot earth anchor longest i could get in town. so i added another 2 ft so in the end i have a 4 foot anchor i often have to winch in sand bottom rivers and you often have to get pretty deep to get hold or your anchor just pulls right out so i cut the two halves to have just over 10 inches of weld instead of just butt welding them together
Reply:Ya but think of just how much money you will save on your next project.
Reply:Originally Posted by 65535Ya but think of just how much money you will save on your next project.
GMT+8, 2025-12-22 04:40 , Processed in 0.127989 second(s), 18 queries .
