my new old welder also wont start..
发表于 2021-9-1 00:26:33 | 显示全部楼层 |阅读模式
I bought the lincoln sa-250 arc welder and drained all the old gas out, changed spark plugs and it started right up and sounded good.The next day after i moved it it suddenly its not starting . i cleaned and sealed the glass gas chamber, but now i'm at a loss..also does anyone know a site to go on to get a copy of the owners manual?
Reply:Could sediment block the fuel line during moving?  Maybe you broke some crap loose?UA Local 598
Reply:I would bet it's fuel related. remove the fuel line at the carb and drain a small amount of gas into a container. Make sure you have enoungh fuel flow.My biggest problem with keeping my SA200 runnig was the sed cup. I took it completly apart. Made sure fuel would flow from it. I then added an inline fuel valve between it and the carb.I don't EVER touch the sediment cup anymore. I turn the new fuel valve On before I start and Off before I shut it down. This also limits the chance of a fire from a leaking carb.
Reply:thank you for all your advice...i'll try these things out and let you know if it worked
Reply:For the Operator's Manual go here & click on the correct code #.http://www.mylincolnelectric.com/Cat...ualsearch.aspxOnly when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
GMT+8, 2025-12-22 06:24 , Processed in 0.095864 second(s), 18 queries .
