Work Light
发表于 2021-9-1 00:26:33 | 显示全部楼层 |阅读模式
What is a good portable 110 volt work light that produces a lot of light without too much heat?
Reply:I absolutely LOVE the halogen lamps.  They produce heat but are really helpful when welding - so much light that they cut through the shade a little even.  I have one small stand alone one and a pair on a tripod stand (Lowes $39 beat northern tool price).I also rely on a 60W drop light with a metal cage, simple cheap and almost disposable.  I like mine because it has 2 outlets on the handle too so it doubles as a light weight extension cord.Hobart LX235Victor 250 Oxy-Acetylene Rig (welding and cutting)Bobcat 773F-350, 1999, 4x4, 16' 10K# trailerOutdoor Wood Burner - 10 cords/year
Reply:I have a small florescent (however it's spelled) drop lamp that stays cool and gives good light for how small it is.  The tube is only about a foot long.  I forget where I got it, maybe at an auto parts store.  It has a clear tube cover that protects the light tube.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Go with the high wattage LED lights, very low power, no heat and very, very bright. Miller Auto Invision 456 + S-62 wire feederC6240B1 Gap bed lathe16 ft3 air compressor16 speed pedestal drillHafco BS-912 Bandsaw
Reply:where do you find good led lights? I want some but don't know where to find them?thermal arc mst400, va4000 feeder, lincoln 175 min, victor torches, miller s32p feeder, air arc k4000 for work.
Reply:Originally Posted by adam21584where do you find good led lights? I want some but don't know where to find them?
GMT+8, 2025-12-22 06:19 , Processed in 0.091609 second(s), 18 queries .
