Will aluminium react with gal?
发表于 2021-9-1 00:26:33 | 显示全部楼层 |阅读模式
I'm pricing a staircase where the customer wants aluminium treads bolted onto steel stringers. Its an outdoor set of stairs so the stringers/risers are gal. My question is will the ally treads react with the gal? should I lay a strip of rubber in between the 2 to prevent contact?Thanks.
Reply:Originally Posted by stampI'm pricing a staircase where the customer wants aluminium treads bolted onto steel stringers. Its an outdoor set of stairs so the stringers/risers are gal. My question is will the ally treads react with the gal? should I lay a strip of rubber in between the 2 to prevent contact?Thanks.
Reply:thanks dave, will do. I'll use anti-foul on the thread too, just to make sure. The aluminium treads are pre-fabbed and are supplied load rated.
GMT+8, 2025-12-22 04:50 , Processed in 0.073725 second(s), 18 queries .
