pipe bending
发表于 2021-9-1 00:26:28 | 显示全部楼层 |阅读模式
has any one tried bending a tube in a pipe bender with the tube filled with 2mm steal shoot blasting media in it with the end pluged up and tacked fast
Reply:Hmm,that sounds like a pita . It also reminds me why i think people should list their city of residence.For example if it said fort lauderdale in your profile i would probably say come on over and use my Pro-tools hmp 200 tubing bender Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:I will agree, everyone should list and answer the questions in the profile.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:was i a hurry figured i would edit it later and cant figure out how i am from lebanon  pa 37 and i work for a deere dealer ship specializing in hydraulic breaker [tramac and indeco] i was also a soldier before that for eight years
Reply:i found it
Reply:How much do you have to do? How accurate does it have to be? What size tubing?A muffler shop may be able to help you with a few bends Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:I have bent tube for years using a torch, thick gloves  and a vise. You can get some good bends with practice. And I now have a JD squared bender. But.... I STILL bend large radius tube the same old way. I don't have a roller that would get me a bend that gradual. It works well, just don't seal wet sand in the tube. Make sure it is dry. Don't ask how I know!!!!!!Last edited by Rojodiablo; 11-17-2007 at 11:22 PM.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
GMT+8, 2025-12-22 04:40 , Processed in 0.092293 second(s), 18 queries .
