Millermatic 130 XP
发表于 2021-9-1 00:26:19 | 显示全部楼层 |阅读模式
Hello:I'm new to this forum and for that matter new to the art of welding.I have worked as a high voltage troubleshooter for the last 35 years.I'm not new to blinding  flashes. Getting to my question.I have been looking at a used Millermatic 130XP for the usual small welding jobs around a small farm setting.I would appreciate any feed back on this unit,pro or con.  It looks like good solid equipment. Thanks for any help you guys may render. ~ Capt.~
Reply:The machine was a sweet little machine.  Keep in mind the limits you'll run into because of lack of top end power.
Reply:Also bear in mind any 120 volt machine drops performence rapidly if it's not getting the full 120 volts of input.You'll never run into a machine that can't be turned down far enough to make a weld, but 120 volt machines can only go so far up under the best conditions.Appreciation Gains You Recognition-
Reply:Good thought Franz. I'll recheck the line voltage in my shop before and after I add some load on. Check for any voltage drop.
Reply:First thing you probably want to do is OPEN & HOLD the oilswitch to the garage.  Then check the wires going to receptacles, these little buggers really need #10 wire to the receptacle if it's more than about 20 feet from the service entrance.Thorw a loadbank on the receptacle, and remove the HOLD, and then do some surge testing to see how your voltage is.Appreciation Gains You Recognition-
GMT+8, 2025-12-22 04:39 , Processed in 0.089857 second(s), 18 queries .
