Short Circuit welds
发表于 2021-9-1 00:26:19 | 显示全部楼层 |阅读模式
Here are three photos of some beads I knocked out this morning. 1].120 wall mild steel2].035 L-563]steelmix4]30cfh 1/8" is generally were I switch to spray, but wished to explore the upper ranges of Short circuit parameters.Note: you can pretend we are old welding buddys and say whatever you like about these welds- talking **** is fun and part of the welding game1st pic: 400wfs/21volts 2nd pic: 400wfs/20volts 3rd pic: 425wfs/22volts w/higher travel rate."after a long day of doing nothing...its gooood to kick back" Pumbaa
Reply:The welds look excellent but what the heck if wfs? Also, I have about 10% of that splatter using CO2.
Reply:Originally posted by Mike W The welds look excellent but what the heck if wfs? Also, I have about 10% of that splatter using CO2.
Reply:Here is another ; the bead on the left is 360wfs/19v and the bead to your right is 360wfs/20v. Slightly different joint , but splatter increase evident with as little as 1 extra volt. Attached Images"after a long day of doing nothing...its gooood to kick back" Pumbaa
Reply:With material this thick (.120) this is the process I would chose if joint position allows.Can Co2 match these 'splatter' levels Attached Images"after a long day of doing nothing...its gooood to kick back" Pumbaa
Reply:Sure Co2 can match that spatter, if you know how to use it, and it's a lot cheaper.Appreciation Gains You Recognition-
Reply:PlanetX,I m wondering why you are welding 1/8" steel in the 180 to 200 amp range? 1/8" is relatively thin material and that high of a heat input sure seems like it will lead to distortion, and HAZ problems. I think most of your spatter problem is being produced by the high volt value that you are using. My suggestion is to drop your voltage down into the 18 to 18.5 volt range and your wire speed into the 260 to 280 IPM range, and see what happens.ESAB Migmaster 250 Hobart Ironman 230Multimatic 215TWECO Fabricator 181i & 211iHH125EZ - nice little fluxcore only unitMaxstar 150 STH - very nice
Reply:Originally posted by Franz Sure Co2 can match that spatter, if you know how to use it, and it's a lot cheaper.
Reply:The third photo looks about the right size for 1/8th material.   The others indicate to me that you are going too slow for the amperage/wfs and material thickness.    I don't know why you would want to explore globular transfer if your gas allows you to go to spray.  Go up to spray and your spatter disappears.   The last photo shows a faint srinkage line down the center.  I've done that before.  i am wondeirng if anyone has had a weld rejected with this line showing?  Is the weld flawed under the face or is it just a suface imperfection????
Reply:Dan- I try to use short circuit when the material is no thicker than 1/8", and go to spray if part/joint position allows from 1/8" upwards.Yes, even 1 less volt showed a significant splatter decrease.Lotechman- Over-welding is a common enough affliction of which I may be sufferingReally I think these welds are at the ragged edge of high short circuit parameter settings. The glob beads would look more like a spray weld w/splatter. Or so I think.The 'centerline' is the last place the weld metal cools, it has been discussed here before, some have stated it is an indicator of too fast travel speed, but there are links contained in the thread that dispute that conclusion- spray threadLast edited by Planet X; 03-21-2004 at 09:07 PM."after a long day of doing nothing...its gooood to kick back" Pumbaa
Reply:Ok, I have a wonder too.  Are you building stuff where you are spraying steel over 1/8 thich or are you just testing?www.urkafarms.com
Reply:Originally posted by Sberry Ok, I have a wonder too.  Are you building stuff where you are spraying steel over 1/8 thich or are you just testing?
Reply:I like to test also. I will try to get some CO2 pics. Can you measure your amperage? I seem to run at 100 amps with .035 wire. One of my many unfinished projects is completing my 28 volt 100 amp alternator hooked up to a 10 hp engine. I have 3 wire feeders besides my Hobart Betamig. I was going to use the alternator for a portable rig.
Reply:Originally posted by Mike W I like to test also. I will try to get some CO2 pics. Can you measure your amperage? I seem to run at 100 amps with .035 wire. One of my many unfinished projects is completing my 28 volt 100 amp alternator hooked up to a 10 hp engine. I have 3 wire feeders besides my Hobart Betamig. I was going to use the alternator for a portable rig.
Reply:The Betamig has not had one problem in over.....25? years. If it did, I would fix it myself. I will get a pic up of my battery charger/welding power supply. It is bigger then the Hobart and probably cost 3 times as much.
Reply:Ok! Im the new kid on the block...here at least but with 37 years of welding almost anything made of metal maybe I can contribute sometning here. at any rate..CO2 versus Argon..in home hobby small stuff nothing to argue about either would do though Id prefer the argon. In the fab shop different story. I want and need the capacity to weld.. short circuit..spray and dare I say it even when large gaps are present (shudder,,shudder) globular, only argo mix will do for this.
GMT+8, 2025-12-22 06:02 , Processed in 0.122949 second(s), 18 queries .
