hello all!
发表于 2021-9-1 00:26:17 | 显示全部楼层 |阅读模式
hello,new to this forum and needing some help.Bought a lincoln sp125 plus from the guys at Pawnstars(the tv show).Sposed to been"tested,works great". It wasn't.Drive gear housing was busted and someone had used bicycle spokes to piece it back together! Ordered and replaced housing but now when i depress trigger the drive gears will turn for 12 seconds then kick off. I let off trigger and it runs 12seconds again. Any suggestions?Last edited by jrayll; 10-12-2010 at 11:56 PM.
Reply:Yes; send it to a service shop. Any local welding shop will know a good repair facility.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
GMT+8, 2025-12-22 07:51 , Processed in 0.089541 second(s), 18 queries .
