?? sheet metal cert. ??
发表于 2021-9-1 00:26:17 | 显示全部楼层 |阅读模式
Does anyone know the/a procedure for welding sheet metal.      I was recently on a job, where a two story commercial building had a single strap of galvananized about 6 in. wide pretty much wrapped around the entire building.    One strip around first story, and another for the second story.      The strips were a couple hundred feet long apiece, so they needed to be welded together.     The material was about a 14 guage, give or take a guage.   At the joint, was a piece laid behind it about foot long and couple in. wider to make joint.   So it was a fillet weld.    I didn't have the proper cert for this according to the inspector, but he let me do it anyway.     Anyone know the proper cert or procedure for this?
Reply:Refer to AWS D1.3-Structural Welding Code - Sheet Steel.
GMT+8, 2025-12-22 06:01 , Processed in 0.097397 second(s), 18 queries .
