Need some good coveralls?
发表于 2021-9-1 00:26:16 | 显示全部楼层 |阅读模式
Hi all. I've been using a cheaper nylon/cotton pair of coveralls, but all it takes is one good spark and I'm ablaze. Any recommendations for some coveralls that's not so quick to catch on fire? I've heard Carhartt is good, but I don't know what to look for. And I mean full coveralls, not the half-overall things.
Reply:lf you have a Tractor Supply near you they usually carry Carhartt full coveralls.
Reply:Dito what Tim M said, thats all I used for welding and machining.LarryMiller XMT 304 CC/CVSyncrowave 180 SDLincoln PowerMig 255XTTermalDynamics 52Lincoln 305GComlpete machine shop to back it up
Reply:I wear these 100% cotton coveralls in the summer.  There cool and no exposed metal.  Good for working on equipment and welding.  Get the white ones.  When people ask if your a bee keeper or painter just say no.  Then they just leave you alone!!http://www.allseasonsuniforms.com/rca01.htm
Reply:Coveralls are nice, but a bit exspensive.  I wear a tank top with jeans and suspenders.  I put on a long sleeve shirt over that, seems to get the job done.Miller 330 a/bp water cooledI believe in gun control, I hold my gun with two hands.  If you want to know why, click here.Buy American or bye America.
Reply:What kind of climate do you work in most, hot, cold. Don't bother with the blends, go 100% cotton but they cost. Also their are different weight to the fabrics, generally the heavier the fabric the better it will stand up. Also get a couple pairs and keep them clean, less grease embedded in the fabric will help with the flammability. Are you doing a lot of vertical and or overhead? I have taken to a leather apron in the last few years and it works well for me."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2025-12-22 04:50 , Processed in 0.089656 second(s), 18 queries .
