Lifan welder generator
发表于 2021-9-1 00:26:15 | 显示全部楼层 |阅读模式
Hey guys been looking at getting a more mobile welder generator combo and came across this on the home depot site. The price is right at 1199 but is there any quality. http://www.homedepot.com/webapp/wcs/...ctId=202196138Specs are a dc welder 40-190. says 50% duty cycle so im guessing thats at max output, Just wanted to see if anyone had any reviews or any info at all.
Reply:Can't atest to the quality of this welder but Lifan is making a name for themselves here in the US in the scooter/small motorcycle arena. I have never heard of any negitive feedback on their product either.StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:Originally Posted by Trx250rracer31Specs are a dc welder 40-190. says 50% duty cycle so im guessing thats at max output, Just wanted to see if anyone had any reviews or any info at all.
Reply:Originally Posted by Sandyit's only a 2500 run watt genset to begin with... Anyway a 2500 watt source isn't going to have very big brass ones. I'd sure think it over real good.
Reply:Originally Posted by Rick VHey Sandy, where did you see 2500 watts?The description on the Home Depot site said, "The generator provides 3750 Watt surge and 3500 running wattage".If it had been 2500 watts then yeah - what you said.But at 3500 watts, it may be possible the welder portion could output say 140 amps at 25 volts and that would be OK for many applications.Still, I would feel a lot better about this if the unit was more like 5500 watts.
Reply:Rick V, go to the link and click on that specifications tab and see how you read it. Pretty shoddy the way it's put together.   Someone not quite familiar with the english language or standard ratings was trying to put together a spec sheet looks like. I guess a guy can pick the wattage you want see and hope for the best. "The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Hey Sandy... there is more technical information `(e.g 3500 watts) under the tab 'Description' than under the tab 'Specification'. I went on the LifanUSA site and while there is a picture of the gen/welder, there is no description or specifications.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:From what I've read in the past, Lifan seems to be a decent company for engines.  I think that if I had a $1200 budget.  I'd be looking at a Maxstar 150s and a 5500 watt generator.  That's what I have and new price would put you in the $1200-1300 range.  Then you would have a good, name brand welder that could be plugged in anywhere and portable power to run it out in the middle of nowhere. As a bonus, the two could be split up later on if you decide to upgrade or one or the other dies.  Maybe I'm a little biased, but the system works good.  The genny I have is a WEN.  It's chinese, but the price was right for one with a blown engine and the parts to fix it was cheap.  I've got roughly $300 invested in my generator and paid about $750 for the Maxstar new.My name's not Jim....
Reply:I agree with going with a quality inverter stick welder and separate portable generator of at least 5000 watts.  Miller, Lincoln and Thermal Arc all make very nice, small inverter stick and stick/tig welders.  Generac makes quality generators, some with Honda engines.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-22 04:43 , Processed in 0.106094 second(s), 18 queries .
