12lb wire spool in millermatic 140?
发表于 2021-9-1 00:26:14 | 显示全部楼层 |阅读模式
is that possible? i hope so cuz i just got the wire today. special adapter needed? any help would be greatly appreciated.
Reply:http://www.millerwelds.com/om/o225311c_mil.pdfSection 4-10 shows an adapter and nut being needed to run an 8" spool (I'm pretty sure thats about 12 lbs) I have no idea if that adapter came with the machine or you have to get it seperately..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DSWhttp://www.millerwelds.com/om/o225311c_mil.pdfSection 4-10 shows an adapter and nut being needed to run an 8" spool (I'm pretty sure thats about 12 lbs) I have no idea if that adapter came with the machine or you have to get it seperately.
Reply:As long as the spool diameter is 8" or less and the spool width is 2" or less with a 2" dia inside hole, the spool will fit just fine.  The weight number isn't the important part.  Normally, an 8" spool of fluxcore wire weighs about 10 lbs.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-22 04:49 , Processed in 0.097112 second(s), 18 queries .
