noob, :D
发表于 2021-9-1 00:26:14 | 显示全部楼层 |阅读模式
Hellooooo, I was curious about all these different routes that I can choose.  I was trying to read it instead of posting another "what should I get" thread, but there was a LOT to read haha.I have been doing oxygen/acetylene welding for a long time, and wanted to start doing some wire feed or tig stuff now.  I have a big wrought iron fence that I wanted to weld a latch onto, and some bolts to put a nice cover on it.  I didn't know exactly how many amps I would need, if wire feed would be better vs tig, if gas or no gas would be better and all the normal questions I guess.  I would also like to be able to weld stainless steel if that's possible with one or the other.  I have pretty much only done any welding with copper since I am an hvac tech.  But I want to be able to weld with a wide variety of metals, and would just like some help in choosing the right welder.I would really appreciate help with this and would gladly trade advice if you're having problem with your heat a/c or a refrigerator at the house for the wrought iron i have 110 or 230, but for the stainless steel that would be more likely at a restaurant or in some kitchen that I work for doing refrigeration work and most likely 110 would be better, and no gas.  But all the input is appreciatedThanks in advance,Corey.
Reply:Originally Posted by CoreyBienI have a big wrought iron fence that I wanted to weld a latch onto.
Reply:For the wire feed there isn't any gas required, but it can be used right? and what would be a decent wire feed machine?
Reply:there is no gas required if you are using self shielding flux core wire.  all other wires require gas.XMT 350 MPa, w/D52-DTA 185 TSWHarris of
Reply:I used oxy-acetylene welding to attach some of the fixtures on my gate. You should be able to handle that alright.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by CoreyBienFor the wire feed there isn't any gas required, but it can be used right? and what would be a decent wire feed machine?
GMT+8, 2025-12-22 06:24 , Processed in 0.092114 second(s), 18 queries .
