asme/api codes
发表于 2021-9-1 00:25:57 | 显示全部楼层 |阅读模式
new to using this site was wondering if someone could help with some info? trying to find asme codes and api codes without having to spend a fortune in code books only need them for information for test appricate any help
Reply:The inspector should be able to give you all the information you need concerning a test.  And wouldnt trust any information given here anyways without verifying it myself first if it means pass/fail a test.Have we all gone mad?
Reply:Originally Posted by sn0border88The inspector should be able to give you all the information you need concerning a test.  And wouldnt trust any information given here anyways without verifying it myself first if it means pass/fail a test.
Reply:it is a written test on the codes for process piping and natural gas piping for a natrual gas company
Reply:Try www.asme.org. they have electronic download versions of codes and standards. Also try www.pdfcatch.com and see if they have any downloadable code information.Last edited by slim83; 10-20-2010 at 08:14 PM.Reason: added more material
Reply:Sounds like your going to need to reference the book in the future then.  Just buy it.Have we all gone mad?
Reply:I'm a member of ASME, so I'm not sure if they allow you to access this if your not one, but they have an online digital library which has a selection of their code books. Also if you go to their site, asme.org, under the codes & standards tab there is also a link to .pdf versions of some of the codes, it helps to know exactly what code book in particular your looking for as they publish quite a few.
GMT+8, 2025-12-22 06:23 , Processed in 0.350108 second(s), 19 queries .
