Aluminum Bungs
发表于 2021-9-1 00:25:34 | 显示全部楼层 |阅读模式
Does anyone know where I can get some 2" NPT aluminum weld on bungs?Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by BrainfarthDoes anyone know where I can get some 2" NPT aluminum weld on bungs?
Reply:I suspect you're already aware of at least parts of the below,but in any case:-they are extremely easy to get the threads ruined bycareless, final installation of the mating male threaded part.-I check the thread fit, cleanliness, chase, graphite spraybefore welding in, then do the same after-I insist on customer letting ME do the assembly install ofthe mating part--to avoid them screwing it up and thenblaming the bung welding job:-checking, cleaning/chasing male threads, graphite spraying,then assembling with appropriate pipe dope-teflon based preferred.-for timing the position of electric pumps, valves, outlets in a 2" FPT flange,using a 2" conduit locknut is wholly handy--as opposed totrying to time the fitting prior to welding, which is still a guessinggame for a bunch of reasons.Last edited by dave powelson; 10-26-2010 at 05:55 PM.Reason: additionBlackbird
Reply:Thanks for the link.  They sure are proud of their stuff at McMaster.  Any other cheaper sources?Also, I have welded many of those fittings.  Mostly for fuel tanks which is what I'm bidding on this time around.  I've been fortunate enough not to have any cross-threading issues.  Appearance wise, conduit locknuts would not fly.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Doubt they are cheaper, but Jegs will have most any bung you want. http://www.jegs.com/webapp/wcs/store...=aluminum+bungQamuIs Heg qaq law' lorvIs yInqaq puS
Reply:http://www.jdaent.com/weld-bungs.htmlhttp://www.goodvibesracing.com/weld_bungs.htmhttp://lmgtfy.com/?q=aluminum+bung
Reply:Originally Posted by BrainfarthThanks for the link.  They sure are proud of their stuff at McMaster.  Any other cheaper sources?Also, I have welded many of those fittings.  Mostly for fuel tanks which is what I'm bidding on this time around.  I've been fortunate enough not to have any cross-threading issues.  Appearance wise, conduit locknuts would not fly.
GMT+8, 2025-12-22 06:19 , Processed in 0.149741 second(s), 18 queries .
