bushing change
发表于 2021-9-1 00:25:29 | 显示全部楼层 |阅读模式
i got this thing ripped down to replace the lower bushing i have to weld a plug in there and use the 100 ton press it will take every thing the press has at lest it not bronze like some are
Reply:Originally Posted by thebighammer1i got this thing ripped down to replace the lower bushing i have to weld a plug in there and use the 100 ton press it will take every thing the press has at lest it not bronze like some are
Reply:tried to post pictures they are not there
Reply:Try photobucket.....always works for me!Have a Jeep Cherokee?  Click Here!
Reply:and again
Reply:Ok, and then?Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:bighammer - Welcome to the forum. Here is a link that will help you figure out how to post pictures. Any other questions, just ask. http://www.weldingweb.com/vbb/showthread.php?t=111John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:those are the directions i followed they are at the top of the page and no pictures [ help]
Reply:tried again
Reply:Send me the pictures and i'll post them. I will PM you my e-mail.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Posting for BH : John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:I had to resize all photos and then noticed that they are actually listed in the attachment section once approved by the welding web to get into the thread. Took me several attempts before I figured out to resize. Good luck.
Reply:thanks MicroZone  the 2 pic shows the bushing . i cut a plug and welded it in the bushing it took 80 ton to get it lose when it crached the every one was woke up  3rd pic  there are some tools i had to build to use a porta power to press off the head  break her down it about 10 feet tall when assembled
GMT+8, 2025-12-22 06:17 , Processed in 0.069887 second(s), 18 queries .
