mig welding help
发表于 2021-9-1 00:25:27 | 显示全部楼层 |阅读模式
Hi i am in need of some advice i have a sureweld110 amp MIG welder and i am trying to weld with it. (I am a noob at this)The metal i am trying to weld is 3mm thick is this okay or to thick.The other thing that i notice is i can lay down a weld but it does not seem to put enough heat into the steel where am i going wrong any help tips would be welcome.Thanks in advanceAlf
Reply:Hello Aesp,I am just playing at being the Walmart greeter here, not familiar with the Sureweld so hang around & someone will come along to comment.  Meanwhile, welcome to the playground.  Make yourself at home.
Reply:Thats about .120 wall right? give her about 280-320 ipms w/18-20volts- that should stick her together nicely."after a long day of doing nothing...its gooood to kick back" Pumbaa
GMT+8, 2025-12-22 07:55 , Processed in 0.068615 second(s), 18 queries .
