查看: 13|回复: 0
3g weld test
发表于 2021-9-1 00:25:23 | 显示全部楼层 |阅读模式
Hi. I am wanting to take the 3g weld cert. with my employer and would like to practice for a few weeks in advance before taking the test. Would like to know if anyone could tell me how to set up the test. Plate thickness I would like to use 1 inch but what degrees do I cut the bevel and should only one of the plates be beveled and the other not? Any advice would be appreciated
Reply:Those specifications can and will vary between employers, the only way to get that information is to see the WPS for your test.Last edited by sn0border88; 10-27-2010 at 08:13 PM.Have we all gone mad?
Reply:Ok. Is there a process that could at least help me? I was thinking two 6" long 1' thick plates one cut at a 45 and the other straight edge and use a 1/4 backing plate.
Reply:Here is a good start, from AWS. Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Thanks for the info. I am going to try this at work. I will upload photos .
Reply:45 degree bevel on both plates, 3/32 gap and landing.
GMT+8, 2025-12-22 07:54 , Processed in 0.090844 second(s), 18 queries .
