A new Millermatic 252
发表于 2021-9-1 00:25:21 | 显示全部楼层 |阅读模式
Hi to All,I just bought the above welder. I have yet to weld with it.Has anybody got anything bad to say about them?Anything Good?Thanks,Jack
Reply:Congratulations!  I have a MM251 and I love it. The only bad thing I can say about your MM252 is that it's at your house and not at mine.StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:I've welded with the MM250, 251 and 252.  The 251 and 252 are both a big improvement over the 250.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by goinssrCongratulations!  I have a MM251 and I love it. The only bad thing I can say about your MM252 is that it's at your house and not at mine.
Reply:Jack772------Buy a 30A spool gun for it and load some aluminum and there's almost nothing you can't fix with the 252.  It will weld thinner metal than they spec it for too, you just have to move fast.  I really like the way you can leave both the regular mig gun and the spool gun hooked up at the same time and  it will auto-sense which one you are using and default to the settings for that gun. I added the multi-bottle low shelf on mine and the tall cable/gun holder to make it handier.I have found that some of the suggested settings on the attached Settings Flip out Folder seem to be a little hotter than necessary. Enjoy your 252, it is a GREAT welder IMHO.  DougMiller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Have not used my 252 a whole lot yet, but so far, me likey!! It welds as good or better then the delta weld 452 I use at work.
Reply:Jack,I'm currently enrolled in a welding program close to where I live, hoping to get an AWS certification when everything is said and done.  I do not own my own welder as of yet, but hope to purchase either the Millermatic 252 or 350P as my first machine when I finally get around to it.  I hope it works well for you, and do keep us updated!Congrats!Scott
Reply:They hold up pretty well. We have a **** ton of 251s and 252s and they weld good(not great) and hold up well to abuse. I don't think they weld that awesome on the high end of SC but it depends on which machine I grab too.
Reply:I did some welds today.  The machine worked great!I cannot find anyway to purge the gas hose and gauges when I am done.I turned down the wire feed to do it but it wastes wire.Jack
Reply:I've had mine for about two years, no problems so far, welds very nice, have the 30A spoolgun with it, it also welds nicely for aluminum. No regrets from this fellow...Guy_48Welding is an art......Millermatic 252Lincoln SP175PlusLincoln 225 AC/DC
Reply:Wasn't the original question asked "a little after the fox was in the henhouse?".Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Originally Posted by DougAustinTXJack772------Buy a 30A spool gun for it and load some aluminum and there's almost nothing you can't fix with the 252.  It will weld thinner metal than they spec it for too, you just have to move fast.  I really like the way you can leave both the regular mig gun and the spool gun hooked up at the same time and  it will auto-sense which one you are using and default to the settings for that gun. I added the multi-bottle low shelf on mine and the tall cable/gun holder to make it handier.I have found that some of the suggested settings on the attached Settings Flip out Folder seem to be a little hotter than necessary. Enjoy your 252, it is a GREAT welder IMHO.  Doug
Reply:Originally Posted by Jack772I cannot find anyway to purge the gas hose and gauges when I am done.I turned down the wire feed to do it but it wastes wire.Jack
Reply:Originally Posted by jdh239I have a 251 and spool gun.  Can I leave it hooked up like on the 252?
Reply:Another problem (to me) the manual explains the Jog Mode, but I cannot find how to get out of it. If it is in the manual I sure don't see it.Can someone help me with this one?Thanks,Jack
Reply:Originally Posted by Jack772Another problem (to me) the manual explains the Jog Mode, but I cannot find how to get out of it. If it is in the manual I sure don't see it.Can someone help me with this one?Thanks,Jack
Reply:Dang Broc,Don't you just love quoting the Owner's Manual for an owner?Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
GMT+8, 2025-12-22 06:21 , Processed in 0.066625 second(s), 18 queries .
