carb??????????????
发表于 2021-9-1 00:25:17 | 显示全部楼层 |阅读模式
Question. Does anyone know what the floats in a marvel carburator are supposed to be set to?
Reply:I don't but it might help if we knew what you were working on. I'm guessing this is for some kind of welder but Marvel made carbs for everything from tractors to airplanes.Tough as nails and damn near as smart
Reply:1/4" from the gasket surface to the closest point on the float.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-22 07:52 , Processed in 0.084510 second(s), 18 queries .
