carb
发表于 2021-9-1 00:25:17 | 显示全部楼层 |阅读模式
My bad yall. Im new to this obivously, the carb i am speaking of came of a late 1960ish SA200 Lincolon welding machine. I am assuming my floats are set to high due to the fact that fuel is leaking out. Thank you,Aric J.
Reply:Also check for trash in the needle/seat.  Even if the float level is correct, debris in the needle/seat will result in fuel bowl overflow.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-22 06:22 , Processed in 0.088138 second(s), 18 queries .
