Plasma Problems
发表于 2021-9-1 00:25:16 | 显示全部楼层 |阅读模式
I just bought a Weldiking Cool Cut 30 plasma cutter and cant get it to work.  I've tried everything I can't start the arc.  It's a $600 machine.  Anyone else have problems with theirs?  Thanks.
Reply:Dear Freind,Please ensure that you use the correct air compressor (Pressure should be 2-3 Bar), if it is OK, some plasma torches has 2 triggers instead of 1 to start the arc (for safetey purposes).NOTE: Don't try to test the arc in the air for several times as it may break the ceramic resistor in the machine.Eng. Katani
Reply:$600 don't get you much as far as plasma cutters go.Have you read the manual?Is it hooked up properly?Have you talked to the place you bought it from?JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-22 07:53 , Processed in 0.095717 second(s), 18 queries .
