查看: 2|回复: 0
Work Platform
发表于 2021-9-1 00:25:12 | 显示全部楼层 |阅读模式
I made a nice OSHA un-approved work/material platform today. 40"X48" starndard pallet size. The base is 2"x2"X1/8" tubing topped with 3/4"X9 mesh, and the sides are 1"X1"X14ga. tubing. The entire project was welded with Hobart Fabshield 21B fluxcore. http://i94.photobucket.com/albums/l1...dingPix062.jpgCutting parts.http://i94.photobucket.com/albums/l1...dingPix063.jpgCold fitting parts.(and it was COLD out)http://i94.photobucket.com/albums/l1...dingPix064.jpgGood old flux core wire. http://i94.photobucket.com/albums/l1...dingPix065.jpghttp://i94.photobucket.com/albums/l1...dingPix066.jpgCorner to corner to make sure it is square.Welded up with one of the bottoms.http://i94.photobucket.com/albums/l1...dingPix068.jpgAlmost all welded up.http://i94.photobucket.com/albums/l1...dingPix069.jpgPutting on sides.http://i94.photobucket.com/albums/l1...dingPix070.jpgSides almost done.http://i94.photobucket.com/albums/l1...dingPix071.jpgSides done.http://i94.photobucket.com/albums/l1...dingPix072.jpghttp://i94.photobucket.com/albums/l1...dingPix073.jpgFloor in.http://i94.photobucket.com/albums/l1...dingPix074.jpghttp://i94.photobucket.com/albums/l1...dingPix075.jpgAll painted and ready to work in the am.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Is that for a Lull?(sp)...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:It is for a regular little dinky 3000 pound electric fork truck for a carpet guy. He is re- doing section 8 appts. and dosent want to have to carry all the trash down the stairs.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:So did you go to his location and do it up in his parking lot?
Reply:Originally Posted by BurnitSo did you go to his location and do it up in his parking lot?
Reply:Do the forks come in under it so the open railing faces out?  If so, how come there are no crossmembers to go under the forks?  I've also seen them with a short piece of chain welded to the hand rail to secure the platform to the mast.  Just looks a little unstable to me is all, I like to know my work platform isn't going anywhere since I've worked out of them a time or two.
Reply:It is mainly for trash cans, forks come under they are 48", the platform is 40" where the forks go.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Sorry to jack...but....Those little lifts are SCARY AS HE%#...used one in a baptist church to get to the roof about 40 feet thru an inside hatch....like being on a postage stamp attached to a popsicle stick...my idiot partner rode it up after me.....and you couldnt control this one from the ground.....450lbs of 2 guys in a one man lift.......Sorry, had to share.....Oh and...section 8......I'd just whip the crap out the window....looks good though!!!Miller blue star 2eLincoln 175
Reply:Tozzi that looks great! but we gotta get you some sawhorses, dudeVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:I used the 400 pairs of old welding gloves in my truck for knee pads. A day in the life of a self employed weldor.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Hey Tozzi....question, it looks like in one of the pics that you are using your miller to run your wirefeeder......it looks to me as if you are not using the miller generator for AC power, but running thru the remote output to the hobart mig....Is this true, or are my eyes going worse??If so, howd you do it??Miller blue star 2eLincoln 175
Reply:The suitcase is a VS(voltage sensing) just like an LN-25. Power cable from the Trailblazer(set on 19V CV) to the suit case, vs lead from the case to the grounded work. The feeder is powered across the arc.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
GMT+8, 2025-12-22 06:24 , Processed in 0.095505 second(s), 18 queries .
