more pics from work
发表于 2021-9-1 00:25:11 | 显示全部楼层 |阅读模式
this is one of two separators i made at work this weeksome of the part were in stock this is one i weldedChuckASME Pressure Vessel welder
Reply:more picsthe weld caps are 10" with 3/8 wall the shell is 6"sched 40the tanginal pipe are 2"sched 40the tangent pipe was welded with .045 wire 17.5V 150ipm 80/20 argon/co2the rest was done with the same wire and gas but @ 19v 200 ipmChuckASME Pressure Vessel welder
Reply:Nice professional work.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:thank youChuckASME Pressure Vessel welder
Reply:Looks great Chuck,on the tank side of the fish-mouth is it a round hole or is the opening like flushVictor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:that's some nice work, bro.
Reply:Originally Posted by clark-kentskiLooks great Chuck,on the tank side of the fish-mouth is it a round hole or is the opening like flush
Reply:Ahhhh,tangential Victor SuperRanger O/A                                         Solar migLincoln Powermig 140Southbend 9in lathe350# kohlswa anvilMiller Maxstar 150 stl etc....
Reply:Pretty amazing. Thanks for the pics.
Reply:Those are some nice looking welds! Did you build the staircase in the background of the 1st pic?Lincoln AC/DC 225/125 Stick Linde HDA-300 MillerMatic DVI MIG Miller Dynasty 200DX Hypertherm Powermax 1000
Reply:Originally Posted by Carl26Those are some nice looking welds! Did you build the staircase in the background of the 1st pic?
GMT+8, 2025-12-22 07:51 , Processed in 0.142299 second(s), 18 queries .
