On Youtube: Through the lense view of three Mig arcs
发表于 2021-9-1 00:25:10 | 显示全部楼层 |阅读模式
Reply:That guy needs help setting his machine.  When using spray transfer, you shouldn't see droplets of metal like that.
Reply:Originally Posted by EngloidThat guy needs help setting his machine.  When using spray transfer, you shouldn't see droplets of metal like that.
Reply:yes...so much smaller that it's a mist.  It should be like spraying from a hair spray bottle..  such small droplets that you really only see the arc.That's why they call it spray.
Reply:They're using a high speed camera, in the weld frame, so it's probably slowed down by 50 to 100 times the normal speed.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by MicroZoneThey're using a high speed camera, in the weld frame, so it's probably slowed down by 50 to 100 times the normal speed.
Reply:I thought it looked more like globular transfer than spray.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-22 07:51 , Processed in 0.092829 second(s), 18 queries .
