connecting Miller 10a to Lincoln dc250
发表于 2021-9-1 00:24:54 | 显示全部楼层 |阅读模式
New guy here, I would like to connect a Miler matic 10a to a Lincoln DC250.  Need to know the how the contacts are wired... just short them  or do they need to be energize and if so what voltage.  I have diagrams for both, just don't know what the Miler needs.  thanks Ed
Reply:Assuming you're looking at DC-250 manual IM-341, the Lincoln requires a set of closed contacts to activate weld output whereas the Millermatic 10A sends out a 115vac contactor control voltage.Therefore, you have to follow the hookup shown in manual IM-341 on page 25 on the right that requires adding a relay (115vac coil) controlled by the MM10A RC3 (manual O1037C) to provide the NO dry contacts between terminals #4 and #2 on the DC-250 and supply 115vac power to the MM10A from DC-250 terminals #31 and #32.  You should provide a ground between the two as well on the GND terminals.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-22 07:55 , Processed in 0.088772 second(s), 18 queries .
