New member with questions
发表于 2021-9-1 00:24:53 | 显示全部楼层 |阅读模式
Hello everybody. My name is Patrick and im (what i would consider) a new welder/fabricator.I have been doing this for about 3-4 years...3 of those years were precision metal working and welding in high school. The last year has been my job for the most part. I work at a high pressure cylinder restoration plant and do repairs to stuff that comes in.My hobby/passion is racing and cars...to be more specific racing my truck. I have a 2004 Lightning with a couple of things done. I friend of mine that has a Lightning as well has asked me to install a Airride suspension system on his truck and maybe his F250 as well.For the most part it would be welding the C-notch in and some other little odds and ends.Here is the kit he boughthttp://www.ridetech.com/store/suspen...0-level-3.htmlIve never done anything automotive welding related and i want some good info on what to do, equipment, and everything ill need to know to do this properly.Im also wanting to make a custom set of traction bars but ill get around to that later
Reply:what does your friend have?I mean you gotta have a couple of 4 1/2 grinders,(I have one for every type of grinder wheel their cheap) cutoff saw, a good die grinder or two, a magnetic level, maybe a protrator, plumb, maybe a datm gauge if you are doing frames, something good for marking with cheapest is soapstone, bevel gauge, clamps vise grips......
Reply:before today is over  members here will tell you that working on cars is not fora beginner(and correctly so). posting some fotos of your beads may gain you some credibility and info.welcome to the forum,Patrick.
Reply:Originally Posted by pistolnoonwhat does your friend have?I mean you gotta have a couple of 4 1/2 grinders,(I have one for every type of grinder wheel their cheap) cutoff saw, a good die grinder or two, a magnetic level, maybe a protrator, plumb, maybe a datm gauge if you are doing frames, something good for marking with cheapest is soapstone, bevel gauge, clamps vise grips......
Reply:Hey Patrick,+1 with weldbeads' response. The experienced fellows here will drill you regarding your level of welding & your comprehension of the entire gamut of issues with any kind of frame welding. Don't hesitate to provide relevant data with your equipment & what/how you plan to engage each project. Most of we 'ol timers see the youngsters/newbies wanting to do projects without a full understanding of issues that can lead to REAL NIGHTMARES if your prep & design implementation is not done with extensive homework. Welding can be quite easy & solid joint bonding very structurally safe if you have the knowledge & experience. You can't weld rusty metal as has been posted here many times & expect a safe & sound application that can/will lead to personal liability & definitely major headaches for you. Don't hesitate to provide all the information requested by the members, be honest with your abilities/equipment/conditions of a project. Just simply remember that your work, knowledge, & integrity will be the nature of your character & honor. Good work always succeeds..... crappy work leads to disaster.DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:Originally Posted by yorkiepapHey Patrick,+1 with weldbeads' response. The experienced fellows here will drill you regarding your level of welding & your comprehension of the entire gamut of issues with any kind of frame welding. Don't hesitate to provide relevant data with your equipment & what/how you plan to engage each project. Most of we 'ol timers see the youngsters/newbies wanting to do projects without a full understanding of issues that can lead to REAL NIGHTMARES if your prep & design implementation is not done with extensive homework. Welding can be quite easy & solid joint bonding very structurally safe if you have the knowledge & experience. You can't weld rusty metal as has been posted here many times & expect a safe & sound application that can/will lead to personal liability & definitely major headaches for you. Don't hesitate to provide all the information requested by the members, be honest with your abilities/equipment/conditions of a project. Just simply remember that your work, knowledge, & integrity will be the nature of your character & honor. Good work always succeeds..... crappy work leads to disaster.Denny
GMT+8, 2025-12-22 07:54 , Processed in 0.066023 second(s), 18 queries .
