Need advice on Bench Grinder Wheels
发表于 2021-9-1 00:24:52 | 显示全部楼层 |阅读模式
Have an old 230v 8" Baldor bench grinder that finally needs new wheels. Its an 812re to be exact. The wheels are 8"-1-3/4shaft.  I don't really care when it comes to kinds of angle grinder wheels etc. but thought i'd get some advice on good quality bench grinder wheels as it is a little more important and in my opinion a more dangerous piece of equipment.I can get Baldor wheels for around $32 online, i need a 36gr and a 60grit but not sure if they are good as others out there etc.Anyone have good advice on which brands to get or not get or where to order from?thanks
Reply:any help here please
Reply:I use Norton wheels on most of my grinders, bench and surface. They are tool room quality and work great. Alot is personal preferance.LarryMiller XMT 304 CC/CVSyncrowave 180 SDLincoln PowerMig 255XTTermalDynamics 52Lincoln 305GComlpete machine shop to back it up
Reply:I good wheel you may wanta try on one wheel is the 3M expander wheel that has different grits the wheel is foam and as it spins it conforms to the work you are working with for fine finshing and a pro job, you got the power to run it.
Reply:Look up MSC, ENCO or Travers online catalog. Norton is definitely quality. You'll find a lot to choose from.
GMT+8, 2025-12-22 06:22 , Processed in 0.093074 second(s), 18 queries .
