cry babie mig
发表于 2021-9-1 00:24:45 | 显示全部楼层 |阅读模式
I have a millermatic 250x machine that is starting to make the most ungodly noises. it acts like the spool is having a friction problem on the spindle. Any one had this problem and if so do you lube the spindle? no you cant fix it with a hot pass.BORN TO LOSE, LIVE TO WIN.
Reply:The squeaky wheel gets the grease. Try it. Use some Vaseline.
GMT+8, 2025-12-22 07:54 , Processed in 0.091307 second(s), 18 queries .
