My turn for a welding cart project.
发表于 2021-9-1 00:24:43 | 显示全部楼层 |阅读模式
I've been looking at building a new welding cart for years and just never had time. Well the day after Thanksgiving I found a roll away tool box that was cheap enough for me to buy and use as a welding cart. I figured I hadn't built something yet so I just bit the bullet and bought something ready made. After I bought it and got it home I came across a friends old welding cart that he was going to send to the scrap yard.  SO now I was torn between making something outta his old cart or using the roll away. So this is what I came up with.I didn't take any pics of what it stated out as but I took everything off except the base and front face that holds the small toolbox. And as with all my other projects I used old parts that I had laying around.Plus it fits nicely in my shelving unit and tucks away out of sight.In with the new and out with the old.
Reply:Very cool, Esteban! Those work lead hangers are a great touch! City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Pretty handy looking cart ya got going there. Look like that ladder is about the only thing without wheels around your place.
Reply:Thats clean, did you re-paint the tool box or match the paint on the cart to it? it looks good. I like the reused stuff!
Reply:What is the door with bars running across it with a lock at the top?Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by SandyPretty handy looking cart ya got going there. Look like that ladder is about the only thing without wheels around your place.
Reply:Very nice!And diffrent.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:good use of the axle shaft and spider gears.I have a sheared pinion gear waiting to be a shifter.Have we all gone mad?
Reply:That's great it looks like it was meant to be together from the start, and if you need a tool it'll always be on the other side of your welder. just make sure you get the locking wheels.
Reply:Pretty trick.
Reply:Great job man!My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Thanks for all the compliments guys.
Reply:Really nice job on the cart. Nothing wrong with recycling a little. John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Good looking setup. I love the wrench lead hangers.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:Very slick!  When put away it's just a toolbox, but pull it out and turn it 90 degrees and it's a welding cart!I might just have to use a similar design one day!
Reply:very well
Reply:very well done. nice
Reply:very well done. nice tires for rolling over cords and such. a home for everything,maybe a fire extinguisher would cool. sweet cart  dayeLast edited by tigmusky; 12-20-2007 at 08:23 PM.
Reply:Originally Posted by tigmuskymaybe a fire extinguisher would cool. sweet cart  daye
Reply:yeah you can mount them horizontally. I've heard of people rotating them occasionally to keep everything in the inside from settling on one side. Don't know if that actually helps to prolong a fire extinguishers life or not.
Reply:Then maybe I will mount a FE somewhere.
Reply:thats nice, i like the spider gear handles
Reply:Looks great!!!!Great ideas and a great use of space!!!Miller 252 Mig WelderMiller Spoolmatic 15AMiller Econotig TIG/ARC WelderMiller Spectrum 375 Extreme Plasma Cutter
GMT+8, 2025-12-22 06:20 , Processed in 0.096304 second(s), 18 queries .
