Destructive testing
发表于 2021-9-1 00:24:41 | 显示全部楼层 |阅读模式
Here are some 3/8" X 4 plates welded and "tested"  Pulsed Spray mode vertical up, .035 wire, 250 ipm, 98/2My assistant on christmass breakBentThen I beat it and broke it. Notice the curve in the steel.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:ONE pass horizontal position.  800 ipmBentBrokenReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Then as usual I got carried away.  I tried 100 ipm, but it wouldn't get into the 3/8 plate enough, so I went to 140 ipm and ran 8 beads.  The machine said 72 amps every time I stopped the arc.  Still in pulsed spray mode.Here is the profile of the beadsA bendBroken.  You can see the lack of penetrationThe veritcal up gave me the best bend in the plate.  All plates were about 2 something inches wide.  Mill scale was removed for all tests.Last edited by David R; 12-27-2007 at 08:44 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Looks like a fun day of breaking things.  I've never tried pulse spray before... We have a machine setup at work that has a pulse option.. I'll have to take a crack at it.Common sense in an uncommon degree is what the world calls wisdom.
Reply:David, thanks for the pics and the hard work.  Like you work.  JohnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:If you weld bolth sides it won't break as easily. Also by not striking it with a hammer will help keep it from breaking.
GMT+8, 2025-12-22 06:25 , Processed in 0.097080 second(s), 18 queries .
