hydraulic tube bender
发表于 2021-9-1 00:24:38 | 显示全部楼层 |阅读模式
Found this on another forum and I thought I would share. Thoughts?http://www.offroadfabnet.com/forums/...read.php?t=218
Reply:It's a hell of a project. If you were taking a course in machining, and needed a thesis project, it is great. As for practicality in building it yourself???? I got my 2" die for $300 shipped to me, with the follower included. He has more than that tied up in machine time and steel. Also, his follower is the most important part of the setup, not the inner die (Big round die) itself. He has a problem with his follower. It is machined from one solid part. And the track on the follower die will gall up over time. On JDsquared, or JMR, the follower has removable inserts. I use Delrin followers for alum. and SS. To machine out the 11 dies I have for my bender, you would spend probably $8000-10,000 in shop time and materials. All in all, I am at about $3000. Mine is manual, and I can buy the kit to convert it for about $800.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Oops. Double post.... anyway, he has done a very good job on it.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Too much work! Try this one. www.gottrikes.com/Tube_Bender.htm
Reply:Thanks for sharing Andy.That guy did some impressive work on the bender.
Reply:Originally Posted by aDreamSoRealToo much work! Try this one. www.gottrikes.com/Tube_Bender.htm
Reply:I am holding out for a Hossfeld.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I have been using this Mitler Bros. bender.I have 1 5/8" and 1" shoes for it.Miller 252 Mig WelderMiller Spoolmatic 15AMiller Econotig TIG/ARC WelderMiller Spectrum 375 Extreme Plasma Cutter
GMT+8, 2025-12-22 07:54 , Processed in 0.106417 second(s), 18 queries .
