thinking about buying this....help!
发表于 2021-9-1 00:24:36 | 显示全部楼层 |阅读模式
serial # g790435211 model # ccka-ms/3718jit does run but has no timer on it. is there a way i can guesstimate the time on it?how much would it be worth? what can i offer for it? where can i get leads from?any info on this welder/generator would be appreciated or links to it as well. thanks everyone. Attached Images
Reply:i wouldn't be worried about hours......  more so that it's had the crap kicked outta it....   i'd wanna get it pretty dang cheap, after tryin it to see if it even worksBill BerryKeith Berry & Son Ltd.machine work, and weldingBear River Vollunteer FD
Reply:Originally Posted by bp626indamixserial # g790435211 model # ccka-ms/3718jit does run but has no timer on it. is there a way i can guesstimate the time on it?how much would it be worth? what can i offer for it? where can i get leads from?any info on this welder/generator would be appreciated or links to it as well. thanks everyone.
Reply:Originally Posted by smawgmawAlmost impossible to guesstimate the amount of running time.  You can go to Miller's website and input the ser# and model# for a downloadable owners manual and to date the age of unit.  It appears you may be missing part of serial number though.  You should have I believe two letters before the numbers, although, I may be incorrect.  What is it worth and what should you offer depends on how much you are willing to spend on it.  Not sure of the value but somewhat less with no leads.  The welding leads can be purchased at any welding supplier.  This machine is the early version of the Miller Legend.
Reply:tried their website. this is what i got:http://www.millerwelds.com/service/locate_om.phpnothing.
Reply:Yes, at one time they were refered to as AEAD-200-LE, then AEAD-200-LE Legend, and then just Legend.  Pretty much all the same model machine with some minor changes here and there through the years.  These machines are some good units when in good physical and operating shape.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:Seemed to work for me.  Dont know.  Click on the button for locate by model name, then scroll down to AEAD-200-LE and highlight that and search should bring you to downloadable pdf file.Last edited by smawgmaw; 11-10-2010 at 07:57 PM.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:Originally Posted by smawgmawHere you go.   http://www.millerwelds.com/service/locate_om.php
Reply:how much compression (lbs) should i be getting out of this thing?
Reply:Try this link..http://www.millerwelds.com/om/o411p_mil.pdf.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thanks DSW, thats what I was trying to do, just couldnt get it to work.A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:Originally Posted by DSWTry this link..http://www.millerwelds.com/om/o411p_mil.pdf
Reply:for that i will take it if you don't if it is close to alabama probably not worth a long drive.timJust some stuff in my shop.
Reply:If it runs, weld, and generates power it's probably worth a few hundred.  Those are good machines, but by the looks of that one it could die at any moment.  I'd lowball it since you have no idea how long this thing will last.Where's the gas tank!?  Nice electric fuel pump.  It should have a diaphram pump on the other side end of the engine.  How does the engine oil look? Black as tar?  Does it look like it still has the original oil filter (screw on filter on the other side)?  Given the care on the outside, I doubt the care on the inside is much better.The "ccka.." model number looks like the engine model.  Probably the serial number is the engine also.  The model is "AEAD-200LE"  The serial is on the same panel, just below the "AEAD-200LE".  It should be stamped in.  It probably starts with "JE".Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
GMT+8, 2025-12-22 11:24 , Processed in 0.095336 second(s), 18 queries .
