Pictures of some beads
发表于 2021-9-1 00:24:31 | 显示全部楼层 |阅读模式
Ok i was asked to take some pictures of some welding that i do to determin skill level.Heres a couple i took on fridayThe first one is a high pressure cylinder 6 pack frame that i was welding fork slots on.The second was a bracket i made to hold the ultrasound test machine from moving.Both were done with a 1/8 7018 rod and a Lincoln 225 Arc welder thats about 40 years old.Then i made a little project so my dad and some of the welders he works with could see it.First is two passes with a 3/32 6013, second is a 1/8 stainless rod and the last is two passes of a 1/8 7018 . Attached Images
Reply:..... Attached Images
Reply:Pat yourself on the back..Looks great from where I am sitting.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Only in my opinion of course.  Which means nothing in the real world Keep practicing
Reply:Looks good from hereYa gotta spend money to make money!
Reply:That is better then some of the structural welds I see at work. Looks goodVantage 300 kubota ,miller 304 xmt ,lincoln ln 25 pro , ranger 305 G, plenty of other tools of the trade to make the sparks fly.
Reply:Thaks for all the feedback guys...i was thinking i was gunna get laughed at for my work
GMT+8, 2025-12-22 11:03 , Processed in 0.093349 second(s), 18 queries .
