What is the hole I'm looking at called? 1/8in aluminum 5052-H34 welded per ASW D17.2 class C. I don't have the piece in front of me to measure the void. Originally rejected as suck back but I don't know, and I'm not sure he did either. if you recognize it I'd appreciate your expertise. Attached Images
Reply:no other holes in the part? for blo out or suck in
Reply:Looks like the end of a weld..Done badly..Rejected because of a crappy welder.That is where the cracks start from every time.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Thanks for the replies.So, is it rejectable?
Reply:Yes rejected, on Visual
Reply:Ummm, yeah it is a rejectable defect. Crater not filled is a stress riser and like the zap said it will crack right there.I'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys? Trade?
Reply:"Always fill yer craters!"My first welding boss drilled that into us big time, he hated craters, even on non-critical parts.Yes, I'd reject it. Buy American, or don't whine when you end up on the bread line.
Reply:jvan100 - In welding nomenclature it is termed porosity, and in welding literature you will find entire chapters dedicated to its causes. OPUS
Reply:defect pin hole from the end of weld add more wire and slope out or trail off caused buy sudden drop off in amps or if tubing and is solid welded its blow out from the trapped gasses expanding w no were to go but out.miller maxstar 150everlast 256pp/wcoolerJD2 model 32 bender2 position hydro band sawlots more
Reply:If it's a tubing or similar type assembly. Always leave a small area unwelded: Someplace easily accessible! Then, weld up rest of assembly and let it cool. Then go back and seal off "vent" before it has a chance to heat up.Weldtek |
