copper?
发表于 2021-9-1 00:24:25 | 显示全部楼层 |阅读模式
i want to make a fountain out of some sheet copper.  what would be the best way to make a tub and weld it.. could i just sweat the seam or would i have to braze it..  also do you think the copper would rust if i put a clear coat on ..  tony
Reply:TIG would be good for welding - sweating would work but you wll probably see the solder at some point.  Copper doesn't rust but it does develop patinas from brown to green.  You could try to clear coat it or let it color naturally.Get it hot and hit it hard...
Reply:You can TIG weld copper fairly easily and you can use a bare peice of solid electrical wire as filler rod.  I use anywhere from 16ga to 10ga for a filler depending on my base metal thickness.
Reply:is it tig'ed with AC or DC?? i believe it's dcStangnetShop Full Of Stuff. Joey
Reply:The miller Tig Calculator says for deoxidized copper, DC straight polarity.  What guage material would you be using?Have a great day.BrianLincoln Mig 215Miller 211Victor Torch SetMiller Maxstar 200SDMiller Syncrowave 250DX Tig runnerMiller Trailblazer 302 running on LPMiller Extreme 12 VS SuitcaseEllis 1600 BandsawMiller xmt350 CC/CVLincoln Vantage 300
Reply:When using electrical wire for filler, be sure to use GOOD wire. Some classes of wire have high allowable ammounts of aluminum and other contaminant. Try a test part with the filler first.You can braze if you want. Not difficult. I'v silver soldered and brazed a lot of copper over the years.If you sweat the joints with soft solder, you MUST have a good mechanical joint (like a pittsburgh seam) first. If the joint sees ANY tension, it will fail.
Reply:Originally posted by BSOK The miller Tig Calculator says for deoxidized copper, DC straight polarity.  What guage material would you be using?Have a great day.
GMT+8, 2025-12-22 11:11 , Processed in 0.094726 second(s), 18 queries .
