my home made punch
发表于 2021-9-1 00:24:19 | 显示全部楼层 |阅读模式
this punch runs off my 26 pm hydraulic  pump that  also  drives  my 5 foot  rollers...10 foot  shear and  10 foot  break and  press
Reply:wheres pic?
Reply:working on it..lolhttp://i67.photobucket.com/albums/h3...Picture005.jpg
Reply:That is impressive.  How did you cut the "c"?  What do you punch?  Did you make the actuator or where did you get it?  When did you decide to weld that strap on the "c", before or after you determined the max?Do you make your own punches? Impressive!!! My little manual Roper Whitney 20 ton serves me for my minimal punching needs.
Reply:i found  the  "C" at a  junk yard....the  srap is n ot  welded on but slides on and  wedges tight..this  way i can take it off for  long reaches on thin material..yes we make the punches (i copied off some from a shop i used to work in) the  bigger machine in the background is our 10 foot break...it will onl do a  max of 3/16 and we also have a home made shear
Reply:Billie:Any chance of posting some pictures of your other tools or plans. I am very interested in them and would like to see how you designed and fabricated them.Derek
GMT+8, 2025-12-22 11:23 , Processed in 0.072771 second(s), 18 queries .
