New member looking for help/info on piece of equipment
发表于 2021-9-1 00:24:16 | 显示全部楼层 |阅读模式
I have a Starweld model SW1 Plasma Arc hardfacing system and I don't know much about it.  It has 2 welders inside of it 1) Thermal Arc PS 3000 and 2) Thermal Dynamics 300 GTS.  I have only just started to weld and this piece of equipment is something I will never use.  I don't know enough about this Starweld system to know if I should sell it or if the 2 welders inside would work for me a novice welder if I pulled them out and used them seperately.  Wondering if it makes sense to somehow use this piece of equpment of if I should sell it to buy something that would work for me because I currently am using a friends to learn on.  I currently have the Starweld on ebay but thought I should get some info from some experts on what they would recommend I do with this equipment.  I would appreciate any help and you may have and if you could explain it to me in layman terms as I have just started to weld.  Thank you
GMT+8, 2025-12-22 12:54 , Processed in 0.135912 second(s), 19 queries .
