Torch and Tanks fittings help needed
发表于 2021-9-1 00:24:13 | 显示全部楼层 |阅读模式
Ok. need some help here fellas. I recently purchased a torch set. I wanted to replace the hose for a longer one. The one it had was 12 feet and I bought one that is 25 feet. I got it in and then the problem. The end pieces that screws onto the tanks is to big. The older line had smaller heads and the new one has bigger. I look at any other tanks and they all have same heads as this new hose. My question is this: Can you buy and adapter that will allow the fitting to work?  I need to come bigger from the tank to the fitting on the hose. If so, what do I ask for and where to get it? Thanks guys. I appreciate it.  One last question since Im rolling here. My torch I bought came in today. I bought it used. It is suppose to be a Harris. On the torch all I read is this:"10 oxygen"Is this how you can tell it is a Harris or is it a Harris knockoff? thanks guys.\whiteyminWhitey____________________________Lincoln Pro Mig 180Clarke Mig 125Clarke Mig 95Hobart Stickmate 205*looking for a chop saw*
Reply:you can buy adapters at local welder supply. make sure you get one for oxygen and one for acetylene.
Reply:Whiteymin, Once you get that problem solved, look for adapters that will let you connect your old 12' hoses to the new 25' for 37'.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by brw_techI think that I might be able to help you with any adaptors that you might need.  We also offer some technical information that may help you deterimine what size fittings that you may have.  We offer a wide variety of welding fittings on our website.  Check it out at http://www.brwtechnologies.com/
GMT+8, 2025-12-22 11:07 , Processed in 0.097479 second(s), 18 queries .
