thick wall piped
发表于 2021-9-1 00:24:11 | 显示全部楼层 |阅读模式
I'm estimating 24" dia, 3" thick wall A106 pipe. Anybody have experience welding thick walled pipe. Full pen per ASME.
Reply:i have done alot of xx heavy but 3"wall never seen it but if you need a rig welder count me in
Reply:What, specifically, is it that you need to know? Originally Posted by fstantonI'm estimating 24" dia, 3" thick wall A106 pipe. Anybody have experience welding thick walled pipe. Full pen per ASME.
Reply:Originally Posted by A_DAB_will_doWhat, specifically, is it that you need to know?
Reply:? A POP QUIZ ?what are we going to have going thru this pipe?idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by prop-doctor? A POP QUIZ ?what are we going to have going thru this pipe?
Reply:estimating means he is  determining the cost of some work in preparation of presenting a bid..he needs to know the productivity factor..the labor..how many manhours to weld such a joint..
Reply:Ah, now I see.  You want us to do your job for you.Come up with a specific question and you might get some help.  Just asking if anyone has ever welded 24x3" pipe is a poor way to go about things.Have we all gone mad?
Reply:That is quite a bit of welding. Probably not going to roll that out.UA Local 598
Reply:pre-heat, post heat, rt, constant fire, rigging, fitting, i can throw you a number but what is it you are trying to bid? just the weld? plan on no less then 48 hrs of welding for 2 men brother-in-lawing, and not running 3/32 either, i would bet dollars to doughnuts that this isnt just a106 though, sounds like some steam piping, how about insulation removal? how about lead paint abatement? next time ask questions, bring them here and we can help, but not without all the parts to the equation, also i asked our estimater here (my brother) and he would bid it for no less than a 100 hrs a weld, hope that helps
Reply:fstanton  -  24" schedule 160 wall thickness is .030" over 2 - 5/16".  Per ASTM what?   OPUS
GMT+8, 2025-12-22 11:10 , Processed in 0.067135 second(s), 18 queries .
