Powcon TIG setup help
发表于 2021-9-1 00:24:05 | 显示全部楼层 |阅读模式
Hi EveryoneI have had my Powcon 200 SMF for about 8 months and I Love it. I have used it mostly for MIG with some stick work. It works great for these but I have wanted to set it up for TIG work as well. I was going to buy a High frequency after market add on box but found a Powcon TIG box on E-Bay for a good price. This TIG box uses high voltage instead of the high frequency that most do. I have it setup in its most basic form, Gas torch with just a switch to start the gas and high voltage. I would like some help to set it up to use the full features of this box. The problem is it has the 17 pin type plug and my welder has the 14 pin on it. I have found the pins for the 30 volts main power, contactor enable and contactor close. I need help with the pins for the remote control and pins for the weld level pot. This is a RT10 and I as told by ARC Products that Powcon didn't make this but had it made by Kemppi. Arc Products didn't really have much info about it. Thanks for any help.Andy
Reply:whoa, hmm, maybe your dealer can setup a new circuit to fit itStangnetShop Full Of Stuff. Joey
Reply:You need to contact Ian at Arc Products.  I don't have their 800 number here at work, but they have a website.
Reply:http://www.arc-products.com/1-800-770-0063http://www.arc-products.com/powcon/index.htmlStangnetShop Full Of Stuff. Joey
GMT+8, 2025-12-22 07:57 , Processed in 0.071291 second(s), 18 queries .
