another stressful event
发表于 2021-9-1 00:24:01 | 显示全部楼层 |阅读模式
The insulation on this particular tank started burning when I welded on the seam right below the site of the burn. This tank was outside when this happened, so I thank my lucky stars that the wind wasn't blowing like mad as it usually does out there.Luckily the skin wrapped around the insulation was sealed good enough to cause the blaze to extinguish itself before it got out of hand.
Reply:Glad it went out.  I had that happen to me, fumes are terrible.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:That could have been bad.. Stay safe!!We need you around here.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Whoa Mark- what kind of tank is that??? I just saw your glove in the pic, realized that is a big piece of equipment.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:These are not the same trailer, but they are basically the same type. T-316 stainless hull used commonly for chemicals- hazardous materials and non haz.a non insulated tanka severly damaged tankanother view of the damaged tankand a few more of insulated tanks similar to the one in the original post.
Reply:Ah - look at all that material !   :drool:John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
GMT+8, 2025-12-22 07:57 , Processed in 0.064555 second(s), 18 queries .
