More Boring Welding..
发表于 2021-9-1 00:23:59 | 显示全部楼层 |阅读模式
This time it's Aluminum!!Roller in the positioner..This is where the bearing was spinning and banging everything out of shape..And it's pretty dirty too..What do we do with dirty Aluminum?Acetone and a stainless brush..All clean now..And all welded back up..180 amps..Gas mix..3/32" Red End..1/16"4043 filler..45 mins..It will be machined tomorrow..Got lots of welding to do today..I get all the fun jobs.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:You're not kidding about the fun jobs.. that looked like a royal pain in the ***. How long did that take? Looks great!!
Reply:very nice!
Reply:Nice job. I like your end roller device, I'm going to have to remember that one. Is 3/32" filler to big to use? It would seem you would have to really shove that 1/16" in at high rate to get that much build up. You seem like you get quite a bit of those shaft jobs. What kind of uses are they for?
Reply:Why did you pick a weave over running stringers? --Gol'
Reply:Welds look great. I envy your skill.______________Clarke 95  Lincoln 135  Lincoln AC 225 ---------I'm an idiot, please talk slowing and simple.
Reply:Originally Posted by jtrapperNice job. I like your end roller device, I'm going to have to remember that one. Is 3/32" filler to big to use? It would seem you would have to really shove that 1/16" in at high rate to get that much build up. You seem like you get quite a bit of those shaft jobs. What kind of uses are they for?
Reply:Originally Posted by Go1lumWhy did you pick a weave over running stringers?
Reply:s##t zap you nailed that one, beautiful beads .
Reply:Boring? Your aluminum welding is never boring Zap - just your humourFire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
Reply:Looks awesome as usual.  David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:sad thing is itll all be gone tommorrow and nobody will ever know how pretty it wasComplete Fabrication Shop specializing in pipe fabrication. Also offering heavy steel fabrication and sheet metal work.
GMT+8, 2025-12-22 08:07 , Processed in 0.097304 second(s), 18 queries .
