My bearing press
发表于 2021-9-1 00:23:58 | 显示全部楼层 |阅读模式
I like the previous post from Berniep. I wish I'd had the time to make a better one. But last night I had to throw together a makeshift bearing press to get a bearing out of my Toyota spindle.  And the weatherman is calling for cold weather and I need to get my daily driver back on the road QUICK! And HF is 50 miles away. Besides, I already had a 6 ton jack. So off to the scrap heap I went. The top bar bent on the first try so I had to flip it, straighten it and reinforce it. Even with 6 tons, I had to heat it with a torch before it let loose. And check out the bottom bar.https://www.weldingweb.com/images/smilies/eek.gif Attached ImagesI'm not a Engineer, I just play one on the weekend.
Reply:Looks like it did the job.Sometimes you just gotta do with what you have right now.
GMT+8, 2025-12-22 08:08 , Processed in 0.090311 second(s), 18 queries .
