TIG gas fitting needed ?
发表于 2021-9-1 00:23:52 | 显示全部楼层 |阅读模式
Hi everyoneI have been trying to find a gas fitting I need for a new setup. I have tried to find this at my local welding store with no luck. What I need is a fitting that is 5/8" 18 RH male on one end and 3/8" 24 RH female on the other. These are the two common fittings used on Gas cooled TIG torches. I just want to be able to switch back and forth with different torches that I have. Dose anyone now of a source for this. Thanks for any helpAndy
Reply:www.mcmaster.com might have what you needStangnetShop Full Of Stuff. Joey
Reply:I've found quite a selection of stuff at https://b2b.airgas.com/
GMT+8, 2025-12-22 08:07 , Processed in 0.109230 second(s), 18 queries .
