new welds please rate my weld
发表于 2021-9-1 00:23:51 | 显示全部楼层 |阅读模式
as all you know im a newibe welder on mig  (220v miller 172)now im using auto dark and i keep practicingthese were t weld horizontal made 1 pass tap 4 , 80 speed , 20 cmf Co2.30 wire Attached Images
Reply:second photoplease tell me how am i did  its ok  ,   isn't  it ?? Attached Images
Reply:Looks good to me, are they all in the same position? True horizontal is across, like on a wall.  Those are basic fillet positions.www.urkafarms.com
Reply:Looks pretty good,i dont see anything wrong with them.looks like they would hold up good.
Reply:Originally posted by Sberry  are they all in the same position? True horizontal is across, like on a wall.
Reply:look great to me, did you clean the metal before you started welding?StangnetShop Full Of Stuff. Joey
Reply:Anti-spatter spray is good to help with clean up.  A spray can will last a long time.  I like straight CO2 but it has more tendency to spatter than other gas mixes.  Welds look good...Get it hot and hit it hard...
Reply:looks great to me....keep practicing!
GMT+8, 2025-12-22 07:57 , Processed in 0.097171 second(s), 18 queries .
