Amp setting for Miller Econotig?
发表于 2021-9-1 00:23:46 | 显示全部楼层 |阅读模式
I have not actually used my Econotig for TIG yet.  I have built numerous BBQ smokers over the past 6 years using the stick but I am now ready to start welding up a few motorcycle frames using 1.25" mild steel tubing.Can anyone give me an idea of the amp setting I should use as a starting point for setting my machine up for TIG?  I also was taught to TIG with around 8 psi on the Argon regulator, is this to high for this application and if so where should I start the Argon psi?Thanks,Jason
Reply:u need atleast 20 psi of argon flow so it dont blow away from the wind and u should be good around 50 to 60 amps with that welder.
Reply:I think you meant Cubic Feet per Hour, i use about 15StangnetShop Full Of Stuff. Joey
Reply:Thanks fellars,
GMT+8, 2025-12-22 07:59 , Processed in 0.221147 second(s), 18 queries .
