projects ????????
发表于 2021-9-1 00:23:44 | 显示全部楼层 |阅读模式
HiI'm learning how to weld and use the other tools in a shop and the guy that's teaching me wants me to make a project any ideas?? may b pics or plans ???
Reply:What can you do?How good at welding / fab are you?Me!
Reply:Alot of people learning to weld make a decent table to weld on, that or a welding cart.Miller Syncrowave 200Hobart Handler 140Thermal Dynamics Cutmaster 38E-Z Tube BenderPlasma Cam DHC2
Reply:right now i suck at welding and now much better at fabrication but i want a kind of challenging project to learn on
Reply:that's a good idea dose any one have pics of a table or cart
Reply:Whet type of welding do you want to do?GasStickMIGTIG?Me!
Reply:lilblaster,One of the most common projects for a welder while learning is a welding cart and/or a welding table.  Building a welding cart or a welding table (or some combination of the two) can be as complex or as simple as you would like to make it.  Here's the first welding cart that I built http://www.improvised-engineering.co....php?f=10&t=10 (also acted as a welding table, although I just sold it along with my wirefeed welder to a friend since I got my TIG).  The welding cart/table I'm in the process of designing for my TIG welder is noticeably more complex than that cart.  Other projects which are great to build at little art projects.  They tend to provide a good deal of practice in welding around corners, and welding thin material.  In order to learn thicker material, I'd always just recommend buying scraps of different sizes/types of metal and then weld things together, and keep going from there.  The more practice you get, the better you will get (even if that practice is just a bunch of rusty scrap steel).--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:you said your getting a stick welder.. so if it doesn't have a cart then theres  your project. or a small table ,if you have a place to get scrap mteal. think of something you can use
Reply:The lincoln site and miller site both offer a list of projects. Could be hobart does too, never really looked.
Reply:there are a ton of project ideas/plans right here on the weldingweb...just spend some time and dig in, there's some really great stuffTalent is a flame. Genius is a fire.- Bern Williams
Reply:Pencil holder.Candle holder.Auxiliary fuel tank.  City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:ok thanks yes your right a stick welder
GMT+8, 2025-12-22 08:12 , Processed in 0.066890 second(s), 18 queries .
