Trailer Frame Question
发表于 2021-9-1 00:23:43 | 显示全部楼层 |阅读模式
I'm going to be building a trailer soon out of some 4"x3" angle I have from a previous job.  Its just going to be a simple 5x10 trailer with a 3500lbs single axle.  I have all my plans layed out on the trailer frame, I'm just not sure which would be the best way to do the corners of the frame.  Should I just cut the angle to a 45* cut and weld together, or notch out a square from one piece so the other piece fits into it, or should I just lay one piece of angle on top of the other.  Just trying to figure out which would be the strongest.  The trailer will be torch cut and stick welded, and I am confident in my welding, just trying to find the strongest combination.Only two defining forces have ever offered to die for you, Jesus Christ and the American G. I. One died for your soul, the other for your freedom.
Reply:Personally, I would cut square notches.  On smaller stuff, I just cut the notches with a grinder/cutoff wheel.  On the bigger stuff I'd rough cut with the torch and dress it up with the grinder.  Of course, there's always more than one way to skin a cat...Work HARDER, not smarter! ------------------------ Miller Bobcat 250Millermatic 251Lincoln Precision TIG 185Hypertherm PM 600Hobart 135 HandlerOxweld 400 FlameMaster
Reply:What he said.  I cut out a square and make em fit flush.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:That's what I was thinking, just looking for some experienced second opinons.  Thanks guys.Only two defining forces have ever offered to die for you, Jesus Christ and the American G. I. One died for your soul, the other for your freedom.
GMT+8, 2025-12-22 07:57 , Processed in 0.092296 second(s), 18 queries .
