Air locker fix it
发表于 2021-9-1 00:23:42 | 显示全部楼层 |阅读模式
My buddy brought this air locker assembly over to my place a few days ago.  He had snapped the air feed line off the distribution hub while attempting to re-route it through the diff.  A quick fix and a new one to add to the list....cheers !-Graham-Mechanical EngineerAutosport Mechanic/Fabricator
Reply:good job! How does he like the locker?
Reply:Hopefully you didn't warp it too much by welding it.  I usually braze them with an O/A torch but, I deal mostly with ARB's and they have copper lines.
Reply:Originally Posted by TSORHopefully you didn't warp it too much by welding it.  I usually braze them with an O/A torch but, I deal mostly with ARB's and they have copper lines.
Reply:Originally Posted by aDreamSoRealgood job! How does he like the locker?
Reply:Originally Posted by grahamtheengineerWell....that rush job turned out to be a joke.  I believe he still has not installed it.
Reply:Nice work!  That is why I go lunchbox locker, there is simply too much that can go wrong when you start adding components like air/electricity.  I drop it in low, I'm locked.  If I wanted "on road performance" I'd have bought a Cadillac!Have a Jeep Cherokee?  Click Here!
GMT+8, 2025-12-22 07:55 , Processed in 0.092940 second(s), 18 queries .
